efan fal270 tips please
Old Aug 13, 2003 | 12:34 AM
hslightnin's Avatar
what a pain in tha @ss i got it in but doesnt really fit into the hole but itll do i guess
where is the wire for the A/C relay at
any other tips are welcome
thanks
Old Aug 13, 2003 | 01:43 PM
hslightnin's Avatar
ok i got the basics wired
ne one no wer the a/c realay wire is
and peaple with this kit did u wire a ignition on wire?, i would think that it would be useless becouse it should run no matter if the truck is on or off if the temp is high enouh
Old Aug 13, 2003 | 02:16 PM
SpankDog's Avatar
Banned
i just installed the kit last week it is easy as hell. i tapped into the wires running to the a/c clutch. our A/C uses a positive signal so make sure you hook it to the A/C + plug. If you tap into the wire at the a/c compressor its the grey wire i believe, or you can use someone elses directions like JDM......and tap into the relay box. The taps are provided in the kit.
http://www.teamjdm.com/id78.htm
if you dont wire the ignition on wire i dont believe your fans will ever run. tonight i am going to wire my manual on and off switch.....hth
Old Aug 14, 2003 | 01:20 AM
promodlightning's Avatar
The on and off switch is just ground, correct....How could I run a lighted switch that way????
Old Aug 14, 2003 | 02:09 AM
hslightnin's Avatar
im goin to REM on fri ill bring the instructions down if u want to make a copy
Old Aug 14, 2003 | 09:33 AM
SpankDog's Avatar
Banned
a lighted switch gets power on its own for the light, you can still make it send a ground signal to the fan controller.
