Any Line Lock kits yet?
That's funny, I was going to post the same thing today...when I thought about replacing my rear brakes.
Edit: Paul's High Performance has had one for a long time but it is $300
PHP Line-Lock Kit - The PHP Line-Lock Kit allows you to release the brake pedal and maintain locked from brakes, permitting a proper burnout and/or pre-load of the drivetrain at the tree without rolling. $300
there was someone selling the dual solenoid kits, but thats a big nono. get the single solenoid kit, i guess we just wait for sal. one of the HALO guys designed and fabbed his own kit, very nice, maybe someone can post the pieces we need so we can all make our own
Hurst Line Loc kit works fine. Just make sure you have the proper line fittings and you will be fine. Nothing special....03 Cobra guys use the same kit.
Double flaring the steel brake lines were probably the hardest, then shaping the aluminum bracket to the correct size and placement. You dont need to buy an extra brake line, but it makes it easier so you can fuss with the flaring while your L is still operational, otherwise you'd have to finish everything in one day or your stuck there. Your first line needs to go from the front of the master cylinder to the line lock, then the second line goes from the line lock to the connection on the abs that the original line connected to. The fittings on the master cylinder and abs are odd sizes, hence the need to either hack your extra brake line or your stock brake line. Will try to post some pics after I come back from my trip if anyone is still interested.
See the second picture.... thats all thanks to my trusty moroso solonoid....
http://www.svt-enthusiast.com/modules/gallery/album98
Ill take some pictures of the setup with the lines and such later. It really is a VERY simple setup.
Nice removal of the blacktop !!!
