Eagle F1 GS CS tires ???
Originally posted by Dan_03Lightning
There's only one way to fly, Nitto 555R's for the street!
These are the ones I'm looking at ....
http://www.racegoodyear.com/products/ultrahigh.html
Dude you had me sold thill I looked at the price on the Super Car Eagle F-1 RR 645.00 Each! No that's just a bit crazy.
Cliff, the GS-C makes a good solo/solo2 tire.
Changes the gear ratio a little since it isn't a 45, but not too bad...keep in mind jack clearances...if it was "close" before you put them on, you'll never get it out from under after without some wood planks.
Dan
Changes the gear ratio a little since it isn't a 45, but not too bad...keep in mind jack clearances...if it was "close" before you put them on, you'll never get it out from under after without some wood planks.Dan
