Want to autocross, need help
I want to try an autocross event but not sure about it. Maybe someone can help. I dont know if its a good idea to put my stock truck in the event, also if i do what kind of preps should i do to my truck? I think it would be a blast any help would be nice, thanks
As long as your brakes are fine and your tires are good, like spank said go have fun.
Before you go remove EVERYTHING that isnt bolted down from both the front and back of the truck.
From Floor mats to maps to EVERYTHING. You dont want stuff flying around in the cab with you as you are yanking and banking.
Good Luck
Doug
PS - You know that Autocross is tough on your tires right ?
Good Luck
Doug
Originally posted by SVT_KY
Put 45 #'s in the fronts and 38 in the backs and
learn to pick your apexes..... Lot's of fun ...
Go walk the course first! then walk it in the reverse of the way you run it.That way you can see the exit of the turn.Also go slow at first to learn the lines then speed up.As you get faster run .5 quart oil OVER the recommende full.That way you will not have any oil psi problems and drain that amount out after the event.Tire psi is very important but a clear head and smooth pedal movements are more important The key to auto xing is being SMOOTH.Stan
SMOOTH = FAST ...
