How much money for full exhaust install?
Around how much money would I be looking at for a full exhaust install. Longtubes, 2 hiflow cats, into a magnaflow mufler.
Thanks for the help
Thanks for the help
I had mine installed at JDM, Long tubes, high flows, Magnaflow catback, grand total about 2200.00, 380.00 for the cat back, 1800.00 for the rest and labor, here some quick advice the Magnaflow catback is a PITA when doing this setup, the quality is good but the fit is poor, I would recommend buying JDM silver bullet or single muffler set up with the Kooks setup or REM's Dynotech setup with there cat back these parts have been test fit and proven to work well, the Bassani cat back should fit both well but it expensive. My install took about 10-12 man hours and Jim was more than fair on labor but two pro's struggled to get it in right, with the right cat back 4 hours max. good luck, Todd
Har..
I didnt put mine on. I had Kenz Muffler in Oxnard do the install. They also built the exhaust..
You can use my shop to do the install... I wasnt saying I would do it personally, I will give you a hand in the install..
I owe to you and your dad for the help on the rear-end...
You saw my shop, its just full of toys, it isnt a professional auto shop
-Dale
-Dale
