pumping gas into your L (problem)
Old Aug 5, 2003 | 02:31 PM
Grandmastr's Avatar
i have to pump my gas real slow or nozzle clicks thinks it has a full tank, its there a way to fix it, i have tried over 30+gas stations and all do the same thing
Old Aug 5, 2003 | 02:34 PM
yysenhimer's Avatar
It's illegal to pump your own gas in NJ.
Just pull the nozzle out a little so the pressure vents.
Old Aug 5, 2003 | 02:38 PM
Grandmastr's Avatar
than it spills
the last time someone pumped my gas, they took 25 mins to get 10 bucks worth of gas in and spilled some on the side of the truck, so i just do it everytime, i know how much i can pull the trigger before it clicks but it takes a good like 20-25 mins to fill the tank up
Old Aug 5, 2003 | 02:44 PM
BADBLACK99's Avatar
He's right just pull the nozzle out just a little so it vents. If you put it in all the way the tank doesnt vent and pressure builds up, the auto shutoff works on a pressure system so it will turn off the pump.
Old Aug 5, 2003 | 02:51 PM
SpankDog's Avatar
Banned
damn, weird. i guess we have good gas and good gas pumps here in GA. The 93 goes in nice and fast
Old Aug 5, 2003 | 03:25 PM
MHMCGILL's Avatar
I had a Honda once that was all of a sudden slow to fill. Turns out some MF put sand in my tank and it stuck at the elbow. Out here we don't have the vapor recovery system for the most part. Just my .02
Old Aug 5, 2003 | 03:31 PM
secstang03's Avatar
also goes out nice & fast
Old Aug 5, 2003 | 03:37 PM
Red_02_L's Avatar
Hey man, you might have a kinked hose?!! Also, inspect for blockage in case some little gangbanger stuck something in there. I've had an incident where the 'hood kids stuck some paper wrappers in the hose, causing a blockage. It took 9 hours to pull the FULL tank and clean it all up. I had to drain the gas also to double check the tank. MAJOR bummer!!! i hope that's not what happened to you!
SpankDog's Avatar
Banned
you know it, thats whats nice about side exhaust, it goes right into the other guys window
Old Aug 5, 2003 | 03:40 PM
Georgia_Moon's Avatar
Same as SpankDog. When I fill up weekly here in Ga, place the nozzle all the way in...put it in automatic flow...no interruptions.I believe that some states may require a different size or type nozzle...
Also hope all you guys have a locking gas cap.
Old Aug 5, 2003 | 03:50 PM
MAC[H]Z's Avatar
If you can't figure out how to put gas in it you may just want to hand over the keys to me....
Old Aug 5, 2003 | 04:03 PM
Six Spd Z28's Avatar
Registered User
Yep....I have locking gas caps on all of my vehicles...keeps honest people honest!!
Old Aug 5, 2003 | 06:28 PM
billarf's Avatar
Yea, they got imported guys with cloth strips wound tight on their head that pump the gas in Jersey. Regular non-import guys get tickets for pumping gas there.
Old Aug 5, 2003 | 06:43 PM
SpeedJunkie's Avatar
No doubt.. i think it takes like what 4 minutes or so?? Hell i dont even know but i know by the time i check the oil it is done!
I did actually have a problem filling up the other day though (first time) It shut off at 3/4 tank, probably just a fluke.
Old Aug 5, 2003 | 06:53 PM
bad00's Avatar
My explorer did the same thing and my uncles escort dose it to but only at cirtain gas stations. spank is right if you pull the nozzle out a little it should pump fine. unless somthing is clogged.
