Fuel Cell ....
Old Aug 2, 2003 | 09:14 PM
ThePyroManiacKid's Avatar
Fuel Cell ....
Where can I get one? Does it use the stock pump?
I need on REAL bad. My stocker hangs way to low, and I keep punching holes in it :o
Need some help ASAP ....
Hopefully I can find one under the $500 mark...
Thanks,
Navi
Old Aug 2, 2003 | 09:22 PM
promodlightning's Avatar
Re: Fuel Cell ....
Thanks,
Navi
Whats this fuel cell for a Lightning
Old Aug 2, 2003 | 09:27 PM
Flying Mofo's Avatar
Banned
Get your truck up off the ground dude. Its not meant to be a slammed cheby.
Old Aug 2, 2003 | 09:48 PM
Your truck must be seriously slammed....
Old Aug 2, 2003 | 10:18 PM
Scott Dunn's Avatar
Re: Re: Fuel Cell ....
Be patient!! its coming soon!
Old Aug 4, 2003 | 11:12 PM
Why yes it is.... laying frame, will be laying body soon.... IRS, CantiLever (Indy Style) suspension ... blah blah blah....
I cheated, its not for a Lightning... Its for my regular F150... but I figured the Lightning guys would know where I can get my kicks
Old Aug 4, 2003 | 11:34 PM
SpankDog's Avatar
Banned
well summit racing or jegs they have hundreds of em dont think any lightnings have one cept for stan as of yet....
Old Aug 5, 2003 | 01:36 AM
RDY2RAC's Avatar
i've had a fuel cell since last spring along with braided lines, fuel rails, regulator and a huge fuel pump, its mounted where the spare us to be. but i dont think that will work for a body dropped truck you could alway throw one in the bed. almost any good radiator shop should be able to make a fuel cell for you. or buy one from summit/jegs but then you may have to run an external fuel pump. and since this is more of a daily driver do not use a foam liner in the cell ince they tend to break down and to clog the fuel filters if you leave fuel in them for an extended period.
Old Aug 5, 2003 | 02:57 AM
Thanks RDY
Problem is, the stock tank has all the sensors on it... but the fuel cell, from say Summit, would not have the holes for the sensors...
I have no problem running an inline pump and a regulator... but will it work if I do not have the sensors and the stock pump?
Besides that, with the Independent Rear Suspension, I had to build a whole new frame from the cab back out of 2"x4" .25wall boxed tubing..... with the rest of the frame boxed in and Xmembered for strength (truck will eventually grow some ***** power-wise out of the stock 5.4) I can easily make room for a cell about 18" deep without any problems....
Thanks for your help,
Navi
Old Aug 7, 2003 | 12:13 AM
Just a little bump. I need this to get my truck rolling.
Old Aug 7, 2003 | 01:18 PM
Ruslow's Avatar
I run a cell that is OBD@ compiate[sp] You have to get one that is close to the stock size and moditifythe full neck so you can pressuze it.Then have a box made to hold the sensors and run lines to the neck so they can pressurize the cell.BUT they can not get ANY fuel on them otherwise they will not work properly and turn the lite on.BIG PITA but it works.I made a pattern for the sensor box. and where it needs to go.But you will still need the fuel level sender which has to be custom due to the ohm values.Stan
Old Aug 11, 2003 | 12:10 AM
****, now that sucks ... I might have to see if I can do something myself .. It isnt for performance, its just to raise it out of my way.
I might see if I can raise it up a few inches I guess.
Thanks for your help.
