Amp Install question
Old Jul 31, 2003 | 07:42 PM
Mastertvtech's Avatar
Hey guys, tomorrow I am installing an amp and was wondering what the best way to route the power wire was. I see the grommet on the pass side that I probably want to come through but don't know the best path to it.
Also, I need to lift the carpet behind the pass seat. I know that I need to remove the seat belt but how about the rear panel?
Any other tips (ground location, mounting,..) about an under seat amp mount would be great too!
thanks,
Lew.
Old Jul 31, 2003 | 07:57 PM
EvilGuy's Avatar
Just go straight on the passenger side against the firewall, down the fender cover, and up through the grommet. There are plenty of holes that you can secure the power wire to. Also, run your power wires away from your RCAs. About grounding, I just used one of the stock studs for the storage box, I just sanded off the paint.
Old Jul 31, 2003 | 08:13 PM
Invalid_access's Avatar
I have had mine ran up through the passenger side door sill for three months now. No problems at all. Don't use a pocket knife to punch a hole in the groument. I nearly cut my finger tip off doing that. I also grounded off one the factory studs. It not a hard task, just take your time and you will do a good job.
