Need HELP fast!!
Old Jul 30, 2003 | 07:52 PM
brad88soslowGT's Avatar
Need HELP fast!!
Just put a PSP 6lb , PSP dual flip chip, 90mm mass air and air filter kit. Went to crank it and it will not idle drove it down the road and it seemed to do fine. Any suggestions.
Brad
Old Jul 30, 2003 | 08:18 PM
mecca's Avatar
First I would check to make sure that your contacts are FULLY clean, and your chip is in all the way and taped in. If that doesn't fix it, check your mass air connections. Also check all the vaccum lines going into the intake boot, which may have come loose while installing the filter and mass air.
-Mike
Old Jul 30, 2003 | 08:28 PM
LightningTuner's Avatar
Mike pretty much covered all the bases Chris. It sounds like either the MAF is unplugged, or something isn't seated right. Check over the rubber boot, and make sure that the plastic lines are sealed into it good, and make sure the one that goes to the drivers valve cover didn't come out. Also check that the boot didn't fold over itself when installing it on the TB.
Old Jul 30, 2003 | 08:46 PM
my dad told me he heard a vacum leak and his friend found it. works great.
Old Jul 30, 2003 | 09:16 PM
mecca's Avatar
So I take it you fixed the problem? Cool.
Hey Sal, nice new sig. Me likes...
-Mike
Old Jul 30, 2003 | 09:22 PM
Rob_02Lightning's Avatar
Hey Brad what r u gonna leave us here with blue *****
Man you just added 50 - 80 HP
LETS HERE ABOUT THE BURNOUTS
WOT BLAST
ALL THAT BOOST
HOW AWESOME THE PSP PRODUCTS ARE
Sup wit tat ???
Old Jul 30, 2003 | 11:55 PM
ASVTFordBoy's Avatar
-Mike
I was about to say the same thing.
