LFP Efan install question
Old Jul 28, 2003 | 10:07 PM
Harley#356's Avatar
Question LFP Efan install question
just a couple quick questions. i did a quick search and sorta found what i need, but i'd like more opinions or definately answers
http://www.nhtoc.com/forum/showthrea...8424#post38424
Thanks!
Old Jul 28, 2003 | 10:59 PM
eatoncharged's Avatar
Banned
as if i actually care ill help you with one bit, use a 10 mm box wrench and lock it on one of the 4 water pump bolts and wedge it so it gets tight then you can use a large crescent wrench to take the fan nut off.
solenoids, i dont know what the hell your talking about but you can probaly mount it on the fan shroud
Old Jul 28, 2003 | 11:01 PM
Harley#356's Avatar
i think i've got everything figured out now. Spanky IMed me and told me everything i should need to know
Old Jul 28, 2003 | 11:26 PM
Banned
id like to know what the hell this solenoid thing is all about, uh can someone shed some light on this.
Old Jul 29, 2003 | 12:40 AM
promodlightning's Avatar
Good question...
Old Jul 29, 2003 | 11:12 AM
Harley#356's Avatar
i'm going to install my efan today in like 10 minutes. hopefully i'll be able to return the favors with any questions when i'm done
Old Jul 29, 2003 | 11:25 AM
rocketir's Avatar
solenoid. you know, like your starter solenoid. its like a relay switch. but the contacts are much more heavy duty. I plan on using that instead of a 30 amp relay to apply power to the fan.
Jes
