Air intake idea?
Old Jul 27, 2003 | 11:13 PM
400HPHD's Avatar
Air intake idea?
I really want to use the foglamp holes for air intakes, like the 5.0's use, has anyone done this or would anyone know what I need to use to do it???? I am sick of scraping the JLP's scoop!
Old Jul 27, 2003 | 11:18 PM
kvv8's Avatar
https://www.f150online.com/forums/sh...hreadid=123513
Is the right idea.
Old Jul 27, 2003 | 11:20 PM
400HPHD's Avatar
Yes, so the orange couplings you can get aty Home Depot right??? And what kind of tubing do I need, the same kind thast JLP uses for their set-up???
Old Jul 27, 2003 | 11:23 PM
Rob_02Lightning's Avatar
If you look in through your wheel well,
you'll see it's actually quite easy.
A couple of bolts and the Fog Lights Out,
then you would need to use a hole saw on the back
to open the back of the Fog Light hole so you can hook up your intake hose
Old Jul 27, 2003 | 11:27 PM
400HPHD's Avatar
The question is.....what kind of hoses and where do I get them??? Home Depot, etc....And what kind of connectors,couplings, or whatever????
Old Jul 28, 2003 | 12:04 AM
Tim Skelton's Avatar
Details here.
For an air intake, any kind of tubing will work fine. You will be going up from the driver's side, through the wheel well and into the engine compartment.
Old Jul 28, 2003 | 12:07 AM
400HPHD's Avatar
Tim...Where did you get the Couplings that go inside the fog lamp holes???
Old Jul 28, 2003 | 01:59 AM
promodlightning's Avatar
Great idea, but this will require some custom fabricating...Im sure you can find all your materials at Home Depot....use 3 to 4 inch flexible dryer hose or even ducting hose...as far as brackets, 2 inch aluminum strips allways worked well for me....
Old Jul 28, 2003 | 04:44 PM
400HPHD's Avatar
In case anyone was interested...I finished this project.
http://nhtoc.com/forum/showthread.php?s=&threadid=3792
