Nitrous install pics
Old Jul 28, 2003 | 04:49 PM
NateTrun2's Avatar
thanx for the compliments guys . Right now I'm running a 96 shot. And I have to give credit to my buddies for that install. They were slaving away while I was at work. hehe
Yes. The bottle is semi dangerous in the cab. I need a blow down tube incase the safety discs break. If they break without one, the cab will fill with nitrous followed by a deafening shreaking sound, probably causing me to wreck while the bottle is blowing out the nitrous. So, yeah, I need a blow down tube. But its not too often that they do break if your bottle is in good condition.
Old Jul 28, 2003 | 08:37 PM
BuzzzLightyear's Avatar
Dont forget to include the fact that you will dirty your underwear You are right they dont blow unless Bottle Pressure goes real high. I use to leave a full Bottle in my mudstain and in hot Texas heat never had it pop.
Nice install
BTW Refresh me are you running a 4lb or 6lb pulley ? Whos chip
Old Jul 28, 2003 | 08:54 PM
NateTrun2's Avatar
sup buzz, hehe . yes, probably will dirty my underwear. Blow down tube is next on the list though. right after built motor, LOL, j/k.
Old Jul 28, 2003 | 09:38 PM
cpeapea's Avatar
im glad you like it nate, we slaved for a good couple of hours, i just taped the boot and stuck the nozzle in there and ran the line to the solenoids. then i changed the plugs as andrew was wiring away at the bottle warmer and arming switches. i have to say though, we hid the solenoids and everything pretty good. we could always put the only visible nitrous line in some black wireing shroud and call it a vacuum line.
Old Jul 28, 2003 | 09:41 PM
NateTrun2's Avatar
hrmm...good idea thats what i was thinking. hey, i'm calling.
Old Jul 28, 2003 | 11:01 PM
Rob_02Lightning's Avatar
what do i use to clean under the hood with?
Originally posted by Rob_02Lightning
Nice install Nate,
Clean under the hood too
I meant it was a clean install under the hood,
not "clean under the hood"
Old Jul 28, 2003 | 11:12 PM
NateTrun2's Avatar
LOL
Old Jul 28, 2003 | 11:29 PM
HANKFAN's Avatar
Here are some pics of my NX install
Old Jul 28, 2003 | 11:31 PM
HANKFAN's Avatar
Oh and the view that most of the local street crowd get's to see now that I have added the NX kit
Old Jul 28, 2003 | 11:33 PM
NateTrun2's Avatar
hank had to show me up lmao!
Old Jul 29, 2003 | 01:29 AM
ShaneMcKenna203's Avatar
switches 101...
is the button purge? then the toggle is nitrous on or off? How does that work? If you go with a dry setting, and all you have is on and off, what determains when nitrous is being sprayed? im used to just a basic set up on my friends mustang with a push button activation switch that is wired to his drivers seat and he holds it while he drives. and just pushes the button when he wants to spray. (when the bottle is on) that is the most simple way, can I get more info on switches and throttle activation and all. thanks, Shane
Old Jul 29, 2003 | 01:38 AM
cyntaxx's Avatar
Wow, your sig is huge....
Old Jul 29, 2003 | 01:40 AM
Probleminfected's Avatar
Re: switches 101...
its all done with TPS or a switch at WOT
buttons can be purge, bottle warmer, on/off, bottle opener
Old Jul 29, 2003 | 02:51 AM
promodlightning's Avatar
Thats one sharp setup, Hank.....
Old Jul 29, 2003 | 09:49 AM
HANKFAN's Avatar
Shane- The switch on the left is the nitrous activation switch which puts power to the WOT switch on the Throtte Body. When I flip the switch on the left it arms the nitrous then when I go WOT it sprays the nitrous. The push button switch in the middle is my purge. And the switich on the right is my on/off switich for my electric fan.
