tps problems
Old Jul 26, 2003 | 02:33 AM
gm killr's Avatar
tps problems
i keep getting the ses light. code is for the tps. no matter how i've tried to adjust it, it keeps coming up. does it have to be replaced or should i keep messing with it?
Old Jul 26, 2003 | 08:20 AM
Rob_02Lightning's Avatar
Need more info,
Do you have an Accu-Fab
or aftermarket Throttle body ???
If you do and you can't adjust it correctly,
you may have to drill it out to be able to get more adjustment from it, I HAD TO DRILL MINE OUT and many others did.
(it's only plastic that's a piece of cake)
Then adjust it
If you have it adjusted correctly and still get the code,
Sorry don't know what to tell you ???
Old Jul 26, 2003 | 03:38 PM
gm killr's Avatar
it's a billetflow s/b t/b
Old Jul 26, 2003 | 09:13 PM
promodlightning's Avatar
Rob, I just had my tps voltage set t REM but it was set to 1.06 volts...the tuner said that with cams this seems to work the best....it somehow simmulates a load on the truck..
Old Jul 26, 2003 | 09:57 PM
Never heard that one before,
BUT WHO KNOWS ???
