Need help? SOS
Old Jul 25, 2003 | 10:46 AM
Dick 4's Avatar
Need help? SOS
Im driving my L on the freeway, I go to excelerate slightly and it starts to spit and sputter and slow down.
Now the only thing it will do is, idol ruff and when I give it gas it sounds like it's going to die.
The whole in-take looks fine and the mass air is plugged in.
I dont have any more ideas right now besides the fuel filter.
Any sugjestions.
Old Jul 25, 2003 | 10:50 AM
Silver_2000's Avatar
What changed ?
Did you clean your K&N filter ? Change your plugs ?
Doug
Old Jul 25, 2003 | 11:10 AM
78f1hundo's Avatar
Bad coil pack......
Injectors are pretty good on these trucks, I would doubt that it would be clogged or bad.
Old Jul 25, 2003 | 11:21 AM
PWR_WHLS's Avatar
Change your fuel filter and try again.
Also - does happen from a stop and rolling into WOT or only at rolling speeds?
john
Old Jul 25, 2003 | 11:29 AM
MaxPower's Avatar
Fuel pump.
My low speed fuel pump developed a crack and caused the EXACT same issue... 2001 L
Go have it checked. Mine was covered.
Old Jul 25, 2003 | 02:07 PM
Black Bomber's Avatar
Check your #3 (I think it is or #6) fuse under the hood.
Old Jul 25, 2003 | 02:08 PM
Dick 4's Avatar
Well the Mo Fo is getting flat bedded to the local dealer.
I have not changed anything recent,
When I start it is sounds like it's running on 5 cyl.
Then when I give it gas it just spits and sounds like it's gonna die.
Son of a Bi**h
?Whats the #3 or #6 fuse?
Old Jul 28, 2003 | 08:03 AM
PWR_WHLS's Avatar
I believe these fuses are under the hood an corrospond to the fuel pump relays?
john
