Dtc 5284
Old Jul 24, 2003 | 12:09 PM
03LightninRocks's Avatar
Dtc 5284
Using the instrument cluster function, I get the following order of displays when going through read outs..... dtc then the next push gives me a read of dtc5284. Can anyone inlighten me on what the code is trying to tell me?
Thanks,
Rocks
Old Jul 24, 2003 | 12:44 PM
Crued's Avatar
I was wayyyyyyyy wrong it corresponds to
Oil Pressure Switch Failure.
In searching for that code, I found many forums with people asking about the same thing. YOu need to have that checked out for sure.
Old Jul 24, 2003 | 12:50 PM
Originally posted by Crued
Do you have a chip? If so it's probably just the OBDII message saying something to the effective the the PCM hasn't completed it's normal routine. It could be something else, I'm just guessing. I'll try to find a code list and reply intelligently.
Yes, I have a chip. I suspected that it was about the chip, but I also have a chitload of other mods that could be causing a dtc.
The mod thyat has me most concerned is the exhaust set up. I no longer have 4 O2 sensors and 4 cats. I now only have 2 of each.
The chip was set up with all mods I have.
A variable that may be a factor is that up untill a couple months ago I was going to the track every week. I would always reset my ecm with the chip at the track by disconnecting my battery. Doing this would have cleared that code out once a week so I would not have seen it unless I happened to check it at the right time. It has been a couple months since resetting the ecm so any codes would still be there as of this morning when I decided to check the tach read outs for chits and grins.
I sure would like to know for sure what the code is saying if you find out.
Thanks for the response,
Rocks
Old Jul 24, 2003 | 12:52 PM
I just saw your answer....CRAP!!!!!!!...wonder why the ses light did not come on?????
I will check it out......thank you.
Rocks
Old Jul 24, 2003 | 01:19 PM
Don's Bolt's Avatar
Forgett about it
the odometer dtc codes are BS
your truck is fine, they all show that same code
Old Jul 24, 2003 | 10:04 PM
Originally posted by Don's Bolt
Forgett about it
Good night nurse!!!!!!!!!!!!!!! You don't know what a relief it was to check this thread tonight and find this post. I had planned on doing some exploratory surgery on my truck tomorrow A.M.
I don't know if ya remember me but my truck was born December 2002 and I have done enough mods on it to void 10 warranties. I could not fathom stripping all those mods to get a pressure switch fixed so I was going to go it alone....LOL.
Anyway...thanks for the help.
Rocks
