60 foot times
Old Jul 24, 2003 | 11:35 AM
shawnting's Avatar
60 foot times
I went to the track last week and just wanted to compare with everyone.
My 60 times were 2.0s all night, 2.002(best) and 2.055(worst)
I have JLP traction bars and QA1 shocks, runing 14.5 wide Hoosier QTPs on a 10 inch rim.
My engine mods are C&L 85mm MAF, Accufag TB, and Superchip.
The climate was 83F and 89% humidity.
The truck was hooking great, I did not have to let off the gas for traction throughout my runs.
Should I expect better from my L or is this the best for my engine mod set-up?
Old Jul 24, 2003 | 11:56 AM
Marc Carpenter's Avatar
I personally believe they should have been a little better.
Somewhere in the high 1.9's. But then again that is just my
opinion.
Old Jul 24, 2003 | 12:02 PM
DEIMATT's Avatar
HMMMM
I was cutting 2.00's consistently at our FFW 2 weeks ago on my F1's with Truck Tracks and the snubber and no spacers on the snubber.
Its was like 92 and about 85% humidity!!
4LB Lower
Flip Chip
CONE
Fast air psp
I am gonna get slicks and better do better than 2.0!!!!
We are in Kansas City
03LightninRocks's Avatar
My best before the 2400 stall converter with slicks was a 1.8x.
After the converter it is a 1.69 so far.
Rocks
Old Jul 24, 2003 | 12:12 PM
whip's Avatar
I believe you should be doing better....BUT holly humidity batman!!! THat may have been hurting you! I have done 1.90's on F1's with simple home made traction devices. Maybe practice, and track prep will help you out. Oh, and cool weather!
Old Jul 24, 2003 | 12:16 PM
TTA89's Avatar
I went 1.87 or 1.89 in a totally stock truck on F1s. How Tall are the tires?
Old Jul 24, 2003 | 12:21 PM
shawnting's Avatar
I guess the converter is really worth its money, but there are such a price difference out there.
Old Jul 24, 2003 | 12:23 PM
shawnting's Avatar
the tires are 28" with 3:55 gears. But what was the temp with those times?
Old Jul 24, 2003 | 12:34 PM
jarmstro's Avatar
I also run 3.55s and am consistent with low 1.60 foot times on my 28 x 10 x 16 Hoosiers.
What tire pressure are you running? With 2.0x 60 foot times you must be spinning bad.
I run 15.5 lbs in my tires and come off the line hard.
Old Jul 24, 2003 | 12:40 PM
shawnting's Avatar
I come off the line as hard as I can also, both punching it from brake and power breaking it. Both ways, it's floored, which I wasn't able to do before the slicks. I might not have the eng mods like you do though.
Hoosier said between 14-17 psi. I was at 16 with tires hot. Again, no spin at all.
Old Jul 24, 2003 | 01:08 PM
jarmstro's Avatar
I probably have a couple more mods than you do...
What do you set your QA1s to? Mine are set to 4 on left side and 5 on right side, don't ask it just seems to work for me. I power brake any where from 1700 to 2000 RPM as per the stock tac.
Are you heating your tire good? How new are your tires?
I run with my tail gate, spare and hitch removed. I do leave my A.R.E cover and passenger seat in /on. Truck with me in it weighs 4964 lbs.
Even prior to my built engine my 60 foot times were mid to high 1.60s.
I got my new engine almost broke in and running very low 12s with a real rich tune at present time.
Old Jul 24, 2003 | 01:11 PM
TTA89's Avatar
A TQ convertor is something you DO NOT want to skimp on. They are expensive for a reason. The cheapo $200 dollar convertors are trash. If you can't afford to do it right then stay stock.
Old Jul 24, 2003 | 01:55 PM
jarmstro's Avatar
Correct and I learned the hard way.
Now have a PI.
Old Jul 24, 2003 | 05:24 PM
JWLightning02's Avatar
What are you revving your truck to while you are staged?
Try about 900-1100. That usually works best for me. Then floor that sucker.
Old Jul 24, 2003 | 05:58 PM
shawnting's Avatar
Thanks for the advice on Torque converters!! My QA1s are set at 6 clicks on both sides. I totally understand the 4 and 5 settings on different sides. Hence the reason our slicks gets worn unevenly! I believe the passenger side gets worn out faster. My slick are very well seasoned, they're actually on their last few runs, regardless, I do not have traction problems. BTW, can slicks be swapped from side to side?
I launched at about 1000-1100 rpms aswell.
Thanks for the responses guys!
