Easterisland
Old Jul 24, 2003 | 03:53 AM
Ak.Silver2K's Avatar
Easterisland
What plug were you the most satisfied with when running a 2# lower and 3 1/2" upper? I left the BR7EF's in when I put the
3 1/2" back on, but it seems to lope a little with them.
Mark
Old Jul 24, 2003 | 05:56 AM
promodlightning's Avatar
To get rid of that lope and get more responsivness back, id put in eithers the TR6 or the IT22.....
Old Jul 24, 2003 | 10:45 AM
easterisland's Avatar
With only 10-12 psi boost TR6's would be fine.
Old Jul 24, 2003 | 02:13 PM
10-12 #'s?
With the KB, 2 # lower and 3 1/2" upper, my boost gauge (auto meter) is up at 16#'s +. Is that too much for the TR6's? If not what gap?
Promodel: been destroying denso's (mostly my fault), think I will wait to put them back in after I get a tune I like.
Mark
Old Jul 24, 2003 | 03:25 PM
That is wierd. I get 15psi with a 6lb lower and 3.5" upper.
Are you sure that is what you have on there? If you do TR6's are still okay IMO. I'd ask JL though if he does your chip.
Old Jul 24, 2003 | 04:00 PM
Lower
I know the upper is a 3 1/2". The lower was a 2#'er on my old block, I am pretty sure the mechanic that put in my built shortblock just transferred the lower over to the built. Do you know what diameter a 2#'er is? Only other explaination is that my boost gauge is off. But I remember JL saying with that pulley set-up I should be seeing around 15-16#'s (if my memory is still holding). You are running a KB aren't you Easterisland?
Mark
Old Jul 24, 2003 | 05:52 PM
I have a KB
2lb lower with a 3.5" upper I get about 10psi
2lb lower with a 2.5" upper I get about 22psi
6lb lower with a 2.5" upper I get about 26psi
6lb lower with a 3.5" upper I get about 15psi
6lb lower with a 3.0" upper I get about 18psi
Old Jul 27, 2003 | 04:09 AM
Easterisland
With the 2# lower and 3 1/2" upper you should be seeing 15-16#'s??
Mark
