is it my chip or my plugs???
Old Jul 21, 2003 | 12:58 PM
cobra97snake's Avatar
ok, im at this party on friday and everybody is wanting a ride in the lightning, so i tell them ok.
well, i take off hard, and everything seems to be working right, but then i get to 120mph, and then it just stops, like the engine has no more power... 120mph and 5K RPM and not shifting into 4th....
i shut it down, and im thinking it was my chip, then i do it again to see if it repeats the problem, well it did but it only got up to about 95mph this time until it did it..
could it be the plugs? because i only have them gapped at .040 because i put them in before i had the 4lb pully, what do you guys think?
Old Jul 21, 2003 | 01:01 PM
VyPeR's Avatar
What was the status of your O/D during this?
Old Jul 21, 2003 | 03:03 PM
NJLightning01's Avatar
How recently have you changed your fuel filter? I have heard reccomendations of changing it with every third oil change. So in the vicinity of 10,000 miles.
That was the problem with my truck, when I had symptoms like you describe.
Good Luck
Old Jul 22, 2003 | 02:40 PM
my overdrive was on.
the fuel filter gets changed about every 5K miles, i just changed it about 2K miles ago....
i think it's one of the plugs, when sitting at idle my idle jumps around alittle bit, im pretty sure it's misfiring.
Old Jul 22, 2003 | 02:44 PM
Silver-Bolt's Avatar
Pull the chip and see it the problem continues.
Old Jul 22, 2003 | 06:14 PM
LIGHTNINROD's Avatar
Check for:
Incorrect timing(chip?)
Faulty or incorrectly gapped plugs
Dirty air filter
Faulty ign. coils
Auto trans fluid level incorrect, causing slippage
EGR not functioning properly
Vacuum leak(s)
Dirty injectors
Binding brakes
Dan
Old Jul 23, 2003 | 07:22 AM
loosebolt's Avatar
I'd say plug or coil pack.
Old Jul 23, 2003 | 01:00 PM
we'll see on saturday!
Old Jul 28, 2003 | 06:27 PM
tlfwatch's Avatar
Question Seems it is electrial problem with computer
First check to see if it might be electrial reset computer by disconnecting ground from battery for about 15 minutes and check chip
