Long tube headers
Old Jul 21, 2003 | 09:13 AM
jred's Avatar
Long tube headers
Is it possible to put Lt's on the stock exhaust system. If so how would it sound?
Old Jul 21, 2003 | 01:14 PM
TimBurntire's Avatar
Not sure what you mean by the stock exhaust system, but if you mean leaving the OE cat-back system on; then yes, you can do that with our "cat-forward" set up. This consists of long tube headers, high flow cats, midpipes, O2 extenders, and all applicable mounting hardware.
I actually did this 3 years ago, with different l/tubes (CFH). I had the l/ts, no cats, and the stock muffler. It was a unique sound that no one else around had. Quite aggressive at WOT, yet not too loud at cruise. It did, however, reverberate alot in the cab.
Old Dec 23, 2003 | 06:44 AM
AmoJohnny's Avatar
older thread, but quite interesting to me, can anyone add?
Old Dec 23, 2003 | 11:25 AM
camcojb's Avatar
You can put longtubes with the factory cat-back; you can't put long tubes on the factory mid-pipe/cat converter setup because they end up way past the stock mid-opipe inlets. They do make a shorty headers that directly replaces the cast manifolds, but you give up most of the torque advantage of the lt's.
I did not like the sound of LT's, hi-flow cats, and the stock cat-back. Changed the tone to what could be best described as a "boat" sound.
Jody
