103 mm mass air
Old Jul 19, 2003 | 09:31 PM
promodlightning's Avatar
103 mm mass air
Trying out REMs , new 103mm mass air....Truck is still adjusting to it but I feel a noticeable power increase upstairs...idle characteristics are excellent along with driveability...truck just seems to pull quite better all around.......
Old Jul 20, 2003 | 01:58 PM
hslightnin's Avatar
what kinda IC fluid is that
Old Jul 20, 2003 | 02:02 PM
cyntaxx's Avatar
Was your tune changed/modified at all to accomodate the larger diameter MAF? If not, how rich were you running before with the factory 90mm MAF?
Old Jul 20, 2003 | 02:06 PM
eatoncharged's Avatar
Banned
i think that is watter wetter if im not mistaken.
Old Jul 20, 2003 | 05:21 PM
IC has straight distilled water and royal purple coolant additive....works the best......
tune was not changed for mass air....was running very fat before...might need to check a/f now...am putting in 20% more fuel up to 4000 rpm in mafterburner......but theres no way I can max out the mass air now...
Old Jul 20, 2003 | 05:52 PM
brad88soslowGT's Avatar
promodlightning : Stupid question, But what are the benefits of runnnig the IC that way! Does it make it run cooler?? If so (I assume) helps a little bit in performance. Every little .001 counts.
brad
Old Jul 20, 2003 | 06:17 PM
It definately makes it run cooler...water cools the best, period....all antifreeze does is keeps water from freezing and corrosion protection...but by me adding a bottle of Royal Purple water wetter I get the best of both worlds...if your in freezing weather I would add a small percentage of antifreeze 25% and water wetter as far as corrosion protection, you dont need it because your not dealing with iron or any type of gasses....AND THERE IS NO SUCH THING AS A TOO COOL INTERCOOLER.....
