question
Old Jul 18, 2003 | 10:11 PM
DR.D's Avatar
question
Is there some way you can see if a coil pack is bad or do I need to take it to someone with some testing equipment, like (gasp) the dealer?
Old Jul 18, 2003 | 11:39 PM
eatoncharged's Avatar
Banned
i could be wrong here but if you do the odometer trick when you start the truck up it might tell you the code of your CP is bad.
basically you hold the odometer reset in turn the truck on keep it held, then it will do a guage sweep, then one of them tells you a trouble code and i think on nloc under the supporting vendors performance specialties forum there are a list of codes.
you could just unplug them one by one and see if there is any difference.
Old Jul 18, 2003 | 11:53 PM
Don's Bolt's Avatar
The odometer trick won't work. you have to go somewhere with diagnostic equipment.
What is the truck doing??????
Old Jul 19, 2003 | 01:38 AM
cyntaxx's Avatar
Can't you just pull each one, start the truck, and narrow down the culprit(s)?
I guess this would only apply if the symptons for the bad CP were bad idling, stumbling, etc....
Old Jul 19, 2003 | 01:41 AM
mecca's Avatar
Hmmm, I thought one of my coil packs was bad. Turns out, I have no compression in my #7 cylinder. Looks like its time for a built engine!
-Mike
Old Jul 19, 2003 | 07:38 AM
cyntaxx's Avatar
-Mike
Already????
Old Jul 19, 2003 | 12:40 PM
DR.D's Avatar
what it does
It misses a little at WOT. I just changed plugs hoping that would correct the issue-put in TR-6s-though it smoothed it out some, it didn't eliminate it. 25K with a 4# pulley and superchip since 10K with no issues. I also have an SES code now. Under part throttle it seems fine. WOT it sputters a little. Can't feel it but you can hear it.
Need diags?
