Need stereo help fast...been milking this project forever...
Old Jul 17, 2003 | 05:15 PM
RhinoSlug's Avatar
and Im dying to finish it tonight. I am using the stock deck and putting in new door speakers and subs. I have an amp that I thought I would be able to turn on using a remote wire from the deck, but one doesnt exist. Can I use the port that is in front your right knee for this and if yes, how do I plug into that? Or where else can I get that signal from? Thanks.
Old Jul 17, 2003 | 05:18 PM
EvilGuy's Avatar
Get a fuse tap and tap into the stereo fuse in the fuse box, I can't remember which leg though.
Old Jul 17, 2003 | 05:20 PM
RhinoSlug's Avatar
I dont even know what a fuse tap is?
Old Jul 17, 2003 | 05:22 PM
EvilGuy's Avatar
If you want to rig it, just wrap the wire around the leg then You can pick up a fuse tap at any radio shack.
Old Jul 17, 2003 | 05:53 PM
illegalspeeds's Avatar
Since you're already going to be behind the deck to tap into the speaker wires for your amp input, just tap into switched power to the radio. That way, your amp will be on whenever the deck has power, and it's fused from the same place as the radio (equals SAFER!) That's what I did on mine, and I did this for a living until last year.
Matt
Old Jul 17, 2003 | 06:05 PM
Edward's Avatar
Ditto. Just tap into the blue wire on the radio harness. This will power your amps when the ignition is in the "on" or "accessory" position.
Old Jul 17, 2003 | 07:01 PM
RhinoSlug's Avatar
Ill tap into the behind the deck but there is no blue wire. Would it be the 12 volt ignition wire or 12 volt battery wire? Thanks for replying.
Old Jul 17, 2003 | 07:04 PM
jabaron's Avatar
12 volt ignition
Old Jul 17, 2003 | 07:19 PM
RhinoSlug's Avatar
Sweet, thanks! Pray I dont fry the electrical system! Peace!
Old Jul 17, 2003 | 07:52 PM
FastAsL's Avatar
DO NOT DO THIS!!!!!!!!!!!!!!!!!!!!!!!!
...chris
