Nitrous / Purge ??
Nitrous / Purge ??
When you purge the air out of the line on a nitrous system, it should appear like a white mist contuniously, correct? I'm trying to figure out what is wrong with my system. I went to the track yesterday and used the nitrous program on my chip and it would pull then bog down, then pull then bog down. This happened all the way down the track. I'm just wondering if I got ripped on my bottle fill the other day. They used the pump inorder to fill it. Could there be air in the bottle? I need some help please!!
Rich
Rich
Do you have a pressure gauge and a bottle heater?
Whats the pressure of the bottle? How much juicr are you shooting? Wet or Dry? Where is the nozzle aimed and at what part of the intake setup is it tapped into?
I have a pressure gauge/ bottle heater. This is a wet NX set-up bought from PSP. The bottle was running at proper pressure according to the gauge. I am running a 75 shot on a 4# pulley and tuned chip per SAL. The nozzle is in the plate sal sells aimed in the intake track.
Rich
Rich
Also I have used the kit before with no problems. I just got the bottle refilled the day before. That is why I am confused. When I purge my line it starts out as a white mist then goes away. Any ideas???
Rich
Rich
