Creek, not the clunk!!!!!!
Old Jul 9, 2003 | 10:15 AM
78f1hundo's Avatar
Ok, how do I fix this........
I have the clunk washers in, and still I have this damn creek at full right turn.
I have heard that you have to grease the steering stops?
What do they look like? Where are they?
Does this sound right?
I do have the bleltech 3/4 drop, could it be the spring?
Thanks guy's.
Old Jul 9, 2003 | 11:13 AM
thepawn's Avatar
Yep, I have it in my Roush setup as well. It becomes more pronounced on a lowered truck because of the change in angle.
If you turn the wheel to the opposite direction and scoot underneath the truck, you'll noticed a "dimpled" area on the inside of the axel, mine was easy to find, since the metal-to-metal rub had made it a shiney little spot.
It is not actually the stop that is making the noise, it is a piece right next to it. I think that on a normal height truck, this area does not rub, but has a very tight clearance, once you change the suspension geometry with the drop, this piece now touches some and makes that groaning noise and full turn.
Daniel
Old Jul 9, 2003 | 12:37 PM
Konig's Avatar
mine did that, grease the steering stops and all will be good. They are on the backside of the assembly, you SHOULD see a very small area that has been rubbed on. Grease the area as well as the "nub" that rubs on it...make sure you do both sides of your truck.
Ill take a pic later if you cant find it ..
Old Jul 9, 2003 | 01:42 PM
78f1hundo's Avatar
A pic would be GREAT!!!!!!
Thanks, guys.....
I just need to know where to grease.
Old Jul 9, 2003 | 07:01 PM
Konig's Avatar
If I remember right, its the **** in the middle, its coverd in grease. I actually put some grease on a few places in the joint as well for the hell of it
Old Jul 14, 2003 | 11:19 AM
thepawn's Avatar
looks similar on mine, and as you can see, mine dosn't have any grease at the moment, hence, I creak.
Dan
Old Jul 14, 2003 | 12:27 PM
Konig's Avatar
damn, that pic is HUGE..shrink it down to about 15% or something... and and YOUR WELCOME 78f1hundo....
Old Jul 14, 2003 | 01:03 PM
thepawn's Avatar
Figured he wanted a detailed pic. :P
Dan
Old Jul 14, 2003 | 01:07 PM
SVT_KY's Avatar
Dan
(*ROAR*)
Old Jul 14, 2003 | 01:08 PM
78f1hundo's Avatar
THANK YOU VERY MUCH!!!!!!!!!
Sorry kind of out of it today, you guy's are the best!
Old Jul 14, 2003 | 01:11 PM
Konig's Avatar
Im sure all the people with 56k modems are loving you
