Break rotor question?
Old Jul 8, 2003 | 07:58 PM
BuiltL's Avatar
How do i remove the stock break rotors from the spindle/hub?
Thanks in advance-ZAch
Old Jul 8, 2003 | 08:01 PM
grinomyte's Avatar
lots of wd-40, pull hard.
Old Jul 8, 2003 | 08:04 PM
SVT_KY's Avatar
Tap gently on the back of the brake rotor with a "helper" ...
Alternating sides of course ... Mine just popped right off
(And we wonder why SEARCH never works .... LOL)
j/k guy ...
Old Jul 8, 2003 | 09:39 PM
Probleminfected's Avatar
Re: Break rotor question?
fronts take off the dust cap, remove the pin, unscrew the nut, pull the washer off , then the bearing, then put the nut back on and pull the rotor off the spindle, catch the rear bearing with the nut, this pulls off the rear seal.
rears big hammer, not wd-40, use spray penetrating oil, hit between the wheel studs until it comes loose. don't hit around the rotor edges unless its a last resort.
Old Jul 8, 2003 | 09:49 PM
Big1Daddy's Avatar
Re: Re: Break rotor question?
Originally posted by Probleminfected
rears big hammer, not wd-40, use spray penetrating oil, hit between the wheel studs until it comes loose. don't hit around the rotor edges unless its a last resort. [/B]
HIT IT REALLY Hard if you had to. We had to.
Old Jul 9, 2003 | 02:23 AM
clonetek's Avatar
is that before or after they got put on upside down? LOL
