6# Lower, stock upper, Metco Aux Idler... Belt?
Old Jul 7, 2003 | 03:16 PM
Crued's Avatar
I have a 6# lower, a stock upper, and I'm trying and failing getting the 'known belts' on with the Metco Auxilary Idler. I've tried the standard 6# (68"), no luck, and even went to Napa and got a 68 5/8" belt and that didn't work.... what gives!.
Old Jul 7, 2003 | 06:27 PM
Lightninforce's Avatar
Cool Belt size
Crued,
The belt that comes with our 6# pulley kit is a 4080685 Gatorback. If you add our idler pulley you should add 1" if your pulley size is 100mm add 1/2" if your using a 90mm.
Mark/LFP
www.lightningforceperformance.com
Old Jul 7, 2003 | 06:55 PM
Crued's Avatar
Is there a Gatorback that will work?
Old Jul 29, 2003 | 09:35 PM
alphadoggy's Avatar
Re: Belt size
Originally posted by Lightninforce
Crued,
Mark/LFP
Mark, I have your 6# lower pulley and a KB blower with a Reichard 3" upper pulley. What size gatorback should I be using? If it is not 68.5" can we work out some kind of swap for the 68.5" pulley you sent me with the pulley? Never installed the belt.
Old Aug 4, 2003 | 01:23 PM
alphadoggy's Avatar
btt
