adjusting exhaust tips
Old Jul 4, 2003 | 11:33 AM
Yeller916's Avatar
my stock tips have become saggy after a few thousands miles...what can i do to get them "back up" in the proper location? thanks
Old Jul 4, 2003 | 11:43 AM
Unoid's Avatar
mine are saggy too.
Old Jul 4, 2003 | 11:52 AM
Silver_2000's Avatar
Get up under the truck and bend the hangers....
Old Jul 4, 2003 | 08:37 PM
animator31's Avatar
I had the same problem
I just installed a Bassani and found that all the top nuts on the U bolts were hand tight and its a 99.
Also rear hanger, the single one near the tips was loose and I could move it a few inches in each direction.
So it could be that it moved or does just need to be re-bent up higher.
-Keith
Old Jul 4, 2003 | 08:44 PM
Unoid's Avatar
I haven't looked under to check it out, will bending require machine tools or a big *** hammer?
Old Jul 4, 2003 | 09:20 PM
animator31's Avatar
Yes, it looks small enough that it could be bent without a ton of effort.
-K
Old Jul 4, 2003 | 11:30 PM
You just need to "unhook" the hangers from the rubber things they slide into. Then bend the hanger - then slide the hanger back in the rubber thing. A big channel lock will help unhooking and a big vise grip to bend them
Doug
Old Jul 4, 2003 | 11:32 PM
LatemodelRacer2's Avatar
the rubber things are heck to get off
Old Jul 5, 2003 | 12:11 AM
hslightnin's Avatar
tru dat
Old Jul 5, 2003 | 12:13 AM
dboat's Avatar
Doug
Funny, your boy, TC, says they have to be cut and welded...
hmm, is someone holding out on me?
Dana
