Tranny fluid change?
Old Jul 1, 2003 | 12:17 PM
Konig's Avatar
Has anyone done or seen a good write up on how to change our tranny fluid? Im going to install a deeper B&M pan and a FTVB this month once all the parts arrive. I guess Im going to go with the Royal Purple ATF unless you guys have a better sugestion. I dont want to pay to have this done when it looks so simple, but I could use some instructions incase the supplied ones arent good. Thanks
Old Jul 1, 2003 | 01:42 PM
Konig's Avatar
bump...
Old Jul 1, 2003 | 04:37 PM
Konig's Avatar
not a single person on here knows how?
Old Jul 1, 2003 | 06:26 PM
E-LO's Avatar
I'm waiting too.
Some people recommend doing a flush of the tranny to get all the old oil out.
Old Jul 1, 2003 | 07:01 PM
Konig's Avatar
its suposidly expensive to do that
Old Jul 1, 2003 | 07:04 PM
E-LO's Avatar
I don't know, I'm trying to find out.
Old Jul 2, 2003 | 09:38 PM
j.b.'s Avatar
Must be summer vacation time with this little response...I bought 16 qts of Mercon 5, undid the lower tranny cooler connection on the radiator and slid a 3/8 diameter rubber hose over the flare end of the tranny line. Got a 5 gal bucket with a lid, fed the hose thru the top. Found a large funnel with a slender neck to go in the dipstick tube, opened 4 qts and made ready to go. Started the truck in idle and started pouring. By the 12th quart, bright red fluid was going into the 5 gal bucket, so I turned the engine off and topped up. Rehooked the lines and went for a test drive. Checked again and finished. Shifted better and I felt better too! jb
Old Jul 2, 2003 | 09:46 PM
'01ArrestMeRed's Avatar
I opted to do the drain & refill myself at 30,000 miles. I pulled the trans pan, r&r'd the filter. I then drained the torque convertor (my '01 has a drain plug on the convertor). I refilled and test drove and topped it off.
After a trip this weekend, I'm real close to 50,000 miles.
