truck Running Ugly
Old Jun 27, 2003 | 09:25 PM
QKSILVR's Avatar
Angry truck Running Ugly
Ok today on my way to work doing about 55mph and the truck acted like it was going to die for spilt second. Like I got no power. It kept doing this. I didn't pay attention to the other guages, just noticed the rpm's would bottom then go back to where they were. I drive home no problems till I am almost home. stumbles liek before and catchse back up.
I pull into garage lift hood with it running. starts running bad and dies. So I start it back up. runs for a bit and notice my Odometer flash ---------- across it. Speedo pegs at 140 and stays there after thr truck dies.
Restart, same thing. I pulled my chip and pushed it in and out a few times.
Started it up runs fine for now. Need to go for a drive later.
Does this sound like bad contact between chip and PCM??
If it does it again I will pull chip and put on stock Maf and see if it still does it.
Old Jun 27, 2003 | 09:26 PM
cyntaxx's Avatar
That ------ seems like a sign that the chip is loose. I'd check the contacts on the PCM too...they may be worn.
Old Jun 27, 2003 | 09:31 PM
wannanicecar's Avatar
duct tape will fix that lose chip. or so i've heard
Old Jun 27, 2003 | 09:47 PM
QKSILVR's Avatar
using velccro right now.
