New Thread On An Old Subject (Oil Filters)
Old Jun 23, 2003 | 06:54 PM
GearHead_1's Avatar
I've searched and read most of the information on the site about oil filter preferences. I thought I would see if the opinions are still the same. What oil filter are you running or do you recommend and why?
Old Jun 23, 2003 | 07:30 PM
LIGHTNINROD's Avatar
I've always(since my second oil change) used the K&N Gold oil filter. Yesterday, I changed the oil again and installed a Canton(replaceable element) oil filter. The K&N always worked fine but I got a 'wild hair' and went with the Canton......................
Dan
Old Jun 23, 2003 | 07:33 PM
MaxTorque02's Avatar
Motorcraft or Purolator Pure One filter. All the more expensive ones (Mobil 1, K&N etc.) is like throwing money away.
Old Jun 23, 2003 | 07:46 PM
Ayrton's Avatar
The Purolator filter seems to be the best unless there is newer data out.
If someone has some links to test please throw them up.
Old Jun 23, 2003 | 07:51 PM
GearHead_1's Avatar
Why?
Old Jun 23, 2003 | 07:58 PM
easterisland's Avatar
I use the canton filter. It looks good, but most of all it fits with my canton cobra R oil pan.
Old Jun 23, 2003 | 08:10 PM
GearHead_1's Avatar
Dan
Any pics of this setup?
Old Jun 23, 2003 | 08:28 PM
cyntaxx's Avatar
Motorcraft FL-820S. Chose it because I think it looks cool.
Old Jun 23, 2003 | 08:34 PM
MISTERgadget's Avatar
I use the OEM motorcraft filter. Read this oil filter study here to find out much more.
http://people.msoe.edu/~yoderw/oilfi...tml#motorcraft
This is an interesting filter. Basically, it is a Purolator Pure One filter cartridge in a Purolator Premium Plus case. Don't be fooled by the differently shaped holes cut into the oil inlet. This is the only difference. This is a good filter design and if you want to get a Purolator Pure One filter, get this one instead: it is cheaper.
Like the Purolator Pure One, this filter cartridge features a very large element surface area (400 sqin), but with many pleats (64). This packs the filter together rather tightly and may restrict flow somewhat. I could identify the Pure One element media by a purple dye they use at the seam. It also has the mysterious assembly string wrapped around the outside of the element. Like the Purolators, it features a spring-loaded metal bypass valve and a nitrile rubber diaphram-type anti-drainback valve. The bypass valve is stamped right into the bottom end cap of the cartridge, so it is all one piece.
You can find out more about the canton oil filter here: http://www.cmfilters.com/spin-on.cfm
Old Jun 23, 2003 | 11:03 PM
Flying Mofo's Avatar
Banned
Motorcraft 820-S
OR
Purolator Pure One
No need to waste $$ away on the K&N or Mobil 1
Old Jun 23, 2003 | 11:56 PM
Originally posted by GearHead_1
Why?
Because they are over twice as expensive and don't do any better job. It's not like it's a big capital output, but why spend more money for no better performance?
Old Jun 24, 2003 | 04:07 AM
Factory_Tech's Avatar
I'm sure someone (Sal?) posted once why you can't use an FL-1A filter, and I can't find it. I'd like to know, though. On my tranny spin on filter I want to use the FL-1AHP (or FL-1AR , I can never remember, but the race vesrion of the FL-1A). The tranny kit calls for the FL-1A, so I know it works, but what is the difference, anyone know?
G
Old Jun 24, 2003 | 04:15 AM
Banned
Aside from not having the anti drain back feature of the 820S, i dont know why you cant use the FL1A. I know the threads match.
Old Jun 24, 2003 | 09:22 AM
wydopnthrtl's Avatar
Thumbs up
Pure-o-later here because it is made with the highest quality components.
From my *first hand* knowledge on the subject, the motorcraft filters are actually the best value. (Quality vs cost)
WOT
Old Jun 24, 2003 | 10:40 AM
AZ fun's Avatar
I don't see it that way. That's why I use K&N gold filter for 4.00's more and use royal purple.
