Spal Intercooler fans?
You can put a jumper wire in the distribution panel under the hood. For some reason it was not working on my L but on Erics (dowheelies) it was pumping. I'm somehow making a shroud for the intercooler fans. Having the fans right up against the heat exchanger does cause some airflow to be diminished since it's right up agianst it.
Originally posted by dirtchicken
I just ordered three of the 7.5" fans to go on my JDM heat exchanger.
2nd is how are the (3) fans powered? are they like electric fans? also if I do electric fans also all in the same day, can I wire them all together to go on on a switch or when the key goes on... or how does wiring work? thanks, Shane McKenna
Shane I don't know if the fan are thermostat controled but if not I would run all three at the same time using a single pole switch and a relay, 3 fans are going to draw some juice and the relay will take the pressure of the switch, If you wiring help for the relay toddabb@aol.com
Saw this the other day. It might be worth looking into.
http://www.sporttruckdirect.com/InterChiller.html
Originally posted by air1kdf
At first I was thinking about the point of diminshing returns, then I realized that the stock intercooler coor is not as "effective" at removing heat as the factory unit.
Gator, as always, your setup rocks!
Originally posted by shawnting
I hope the diameter of the fans are of the entire fan and not only from blade tip to tip. Just a thought
Thanks, Shane
