Will this work?
Will this work?
Will this work on the Lightning?
http://www.snowperformance.net
I assume a lot of tuning would be needed, but does anyone know if the results would be worth it?
I did some intense research on it.
YES IT WOULD GIVE GREAT ADVANTAGES AND HP
"BUT
Like you said LOTS OF TUNING and here's where it gets dangerous.
The reason it works is because it basically shoots antifreeze into the air intake and lowers the inlet temp BIG TIME. The Extra HP comes from not only the temp drop, but also from the massive High Timing you can now run with no pinging.
Which means you will clearly need a dedicated tune soley for this purpose.
And due to the extremly hi timing you now run, this would once again put your Motor at the mercy of the Rod Gods in the event a filter or injector clogs or you get a bad tank of gas, or even worse IF YOU RUN OUT OF ANTI-FREEZE
I say Anti-Freeze because you can also run it on Windshield Wiper Anti-Freeze, (thats basically what it is)
I almost bought a kit a yr ago but then decided on juice,
much easier for me to tune it.
"BUT
