Funny noise from radio
I just bought a new '03 Lightning a week ago. So far I love it but I hear this high pitched whirring sound, at first I thought it was the fuel pump (it's not the supercharger). It is real faint and after further poking around realized it's coming from the actual radio (the 6 disc changer). Turn off the radio, turn of the annoying sound with a little delay. Turn on the radio, it's back. It almost sounds like a computer fan. What the hell is the noise? And, will Ford be able to pinpoint or am I better off at an aftermarket radio shop?
Ok, well... if you listen to the CD player, do you still get it? Or is it just when your in 'FM/AM' mode? I know when I listen to my AM stations, i get a lot of whirrling noise depending on where I am at. And I have gotten it on other FM stations. But more so on AM.
If its doing it with your CD Player as well, then I would suggest something isn't right
Re: Funny noise from radio
BTW have you changed the OEM speakers at all? I was wondering if the extra draw would cause the amp to heat up.
My '03 is less than a week old and I have the same problem. My L is due back to the dealer tomorrow for minor flaw touch ups. The radio noise is on the list.
I will let you know what they tell me, before you go to an aftermarket and shell out some cash.
Dan
Dan
The CD player in my '03 L does exactly the same thing as I think you are describing. In my case, it is the mechanical noise of the CD drive mechanism. I'm a little disappointed in it, since the one in my Sport Trac doesn't do it (although the L's unit is obviously updated a little from the ST's), but not disappointed enough to get it replaced. I suspect that it may be common to all or most of them.
This is the only acceptable way to fix it.
The CD-6 decks have a built in fan that sometimes can be the culprit for the noise. I noticed on my CD-6 that there was some radio interference entering the system.
I agree that would fix it, however I'm just not a fan of after market units for two reasons. 1. Almost nobody would want to break into my truck for a stock radio. 2. Personally I just like the look of the factory system. No offense please. BTW that is a nice head unit.
