Need pics of how to install serp belt
Old Jun 16, 2003 | 08:34 PM
00 SVT TOY's Avatar
Question Need pics of how to install serp belt
I have a gatorback serpantine belt and s/c belt i am installing with my 4 lber, and I was wondering if there is a how-to somewhere with some pictures of what I read in the search I did on this. Can somebody show me where to put the pry/breaker bar to push down and get the old one off. Also, is this the best/only way to do this, any other tips or tricks would be great.
Thanx,
Bill
Old Jun 16, 2003 | 09:18 PM
soap's Avatar
Re: Need pics of how to install serp belt
The breaker goes into the tensioner (passenger side infront of IC resevoir). Push down and remove the belt.
--Joe
Old Jun 16, 2003 | 10:32 PM
Rob_02Lightning's Avatar
Here you go Bill
Old Jun 17, 2003 | 12:18 AM
00 SVT TOY's Avatar
Thanks Joe and Rob for the help and that picture, I hope it goes OK with the pulley off, I've heard it's a b1tch to get it off.
Bill
Old Jun 17, 2003 | 01:34 AM
hslightnin's Avatar
Bill
use a car lift
took me 6 hours bymyself and on the ground no jacks
Old Jun 17, 2003 | 02:17 AM
00 SVT TOY's Avatar
Holy Crap!! that doesn't sound like fun at all . Best I've got are my rhino ramps and jackstands, i hope that's good enough lift for me . I guess i'll find out.
Thanx for the heads up,
Bill
Old Jun 17, 2003 | 06:23 AM
00 SVT TOY
If all your doing is taken off the stock Caged Pulley
and installing a 4lb'r and the belts, the entire job took me less than an hour and that was working on a rock driveway on my back. And the first time ever doing it
Very easy Install
Take tranny inspection plate off
Remove a Convertor Bolt
Install the Bracket (stops the Motor from spinning)
Remove the three Cage bolts
Use the included Allan Head Socket to take stock pulley off
Change Assy Belt right then (if you are)
Install new 4lb'r with included allan head bolts
Install new S/C Belt
Take That bracket off the Flywheel
Put inspection plate back on
YOUR DONE
Sal has step by step instructions with Pictures here
http://www.powersurgeperformance.net/pulley_install.htm
Old Jun 17, 2003 | 09:47 PM
00 SVT TOY's Avatar
Thanks Rob, that is the kind of help I need and exactly what I needed to read. Hopefully I will get it done this weekend .
Thanx again,
Bill
Old Jun 18, 2003 | 12:45 AM
Fast Gator's Avatar
Rob-------You are DA MAN
You even pulled your motor to take a picture of the belt routing
