Did i blow a plug or what ?
I think i blew a plug... If i give the truck a little gas it will start to stutter and shake. What do you guys think this problem is??
Plug
chip
etc...
Plug
chip
etc...
Open the hood and if you hear a pretty loud exhaust noise and the coil pack banging up and down against the fuel rail you probably blew a plug. If not you may have a bad coil pack, bad IAC or something?
If you blew a plug you would know it! It sounds horrible. Loud azz exhaust leak. Pop the hood look at the coilpacks if one is missing from its normal home then that sucks. Either way it sucks when your truck runs crappy. Let us know what ya find. -Mat-
If your truck is a 99 or 00 it could be your fuel pump going bad or one of the hoses may have popped off... It happened to me and is a known problem with these two years..Good luck!
Well the problem with my truck was the fuel pump. I droped it off at R.E.M Today and had them change that and the plugs. They told me it should be done around 5 o'clock today (friday).
Johnny
Thanks for the feedback though
Johnny
