Fuel Pressure
fuel pressure
agreed
I get around 30 at idle and just above 50 at wot with 12lbs. This is on a autometer phantom electric fuel pressure guage.
Originally posted by air1kdf
Boost has nothing to do with it unless your leaning out.
the fuel regulator is boost sensative unit so how would boost not matter. Thats why there's a line going to it
sal's told me before that with the line connected its about 31 to 32 psi and with it off around 39 to 40 psi.
. sal's told me before that with the line connected its about 31 to 32 psi and with it off around 39 to 40 psi.
I guess you learn something every day. But I've never heard of a stock fuel setup making any more or less than 52 lbs at WOT. That's from no pulley to 8lbs over. And it could be pressure sensative and not make a difference past a certain amount of boost. Maybe I was just misinformed.
In any event, my gauge(AutoMeter) moves very linearly to my gas pedal.
i fried a few valves once w/ out the fuel pressure vacumm line hooked up. boy was that an expensive mistake
w/ my 50 lb. injectors i set my fuel pressure at 29 psi under vac. and it comes up to about 45 under boost making 15 psi using a 10 lb. lower
