How Long Do the Factory Brakes Last ?
Old Jun 10, 2003 | 01:56 PM
cyntaxx's Avatar
Originally posted by RTKILLA
stock lightning brakes suck monkey *****!
We need to have someone make us brakes that are pretty close to the same size for us drag racers that will stop allot better and reduce the fade aswell.
brembo's are nice but then you can't even fit a 16 inch wheel on front, screw that.
Maybe Wilwoods?
Old Jun 10, 2003 | 02:27 PM
Rob_02Lightning's Avatar
Thanks All
Sounds like it's worth changing them now.
Napa ceramix seems to be everyones choice, I assume you buy them from a Napa Automitive Store, (that would make sence)
There may still be one of them around, I'll have to keep my eye out, it seems Auto Zone has made there mark around here lately and shut down all the US-1's, Aids, and the small name-less places.
BTW,
I know about the wear down piece SVT KY, but I thought our stock brakes would be good for at least 30-50K. I guess not hu ?
Any special tools needed or the usual allan key socket, a set of clamps to open them up, etc ???
Anyone on line sell them ???
BTW
Good One Gator
Old Jun 10, 2003 | 02:58 PM
SpankDog's Avatar
Banned
Mine are squeakin sometimes at 31k maybe i should take a look at them........
Old Jun 10, 2003 | 05:27 PM
J15BIG's Avatar
17k and they work perfect with almost zero noise
Old Jun 10, 2003 | 05:31 PM
RipNRun's Avatar
Just hit 12K late last week (2 weeks of long travels on the L) and mine just started to squeek also. Guess I'll try the NAPAs, too.
I did get a little to close to the sand (went to the Gulf coast week ago Friday). Squeaking started soon after that.
Any of you FL or CA guys that live close to the coast have any advice on making sure I've "de-sanded" as well as possible?
Thanks,
Rip
Old Jun 10, 2003 | 05:50 PM
easterisland's Avatar
I installed new front pads last week. I used the Raybestos QS ceramic pads, part # PGD702QS. I should have put these pads on a long time ago there is almost no dust. I no longer have the brake squeal which I hated. I had about 23K miles on the front stock rotors and pads. I also notice my rotors have small cracks in them. I have some brembo replacement rotors for the front. I have rotors and QS pads(#PGD711QS) for the rear also. I need to find time to install all of this stuff.
Old Jun 10, 2003 | 08:46 PM
SVT_KY's Avatar
Rob,
You will need a T-45 Torq to remove the pads ...
Don't use a cheapo one, or you will be buying the
new bolts in your Honda ... <Ask me how I know that!?>
Cliff
Easter ...
What's possible on the back brakes given that the emergency brake
is there? Can we just disconnect and put a set of REAL brakes
on there? Then we need a differential braking system .. <grin>
Old Jun 10, 2003 | 08:54 PM
Ask skelton about the rear brakes. He probably has done some research on it. Most of the braking is done in the front anyway and the stock system gets it done for what I need.
Old Jun 10, 2003 | 11:11 PM
thepawn's Avatar
Raybestos QS ceramic pads = NAPA Ceramix
same pad, just oem'd.
Cliff -- other then rotor swaps to brembo slotted/drilled or RUSlow's slotted stuff, the only thing I've come across is AP-Engineering/Stillen just came out with a rear calliper kit.
Dan
Old Jun 11, 2003 | 06:41 AM
Great info all, I'm on it
Thanks for the #'s easterisland + SVT KY
PGD702QS for the front
PGD711QS for the rear
T45 Torq
Old Jun 11, 2003 | 09:48 AM
Cali L's Avatar
RipNRun-
I live a block off the water and have had no sand problems. I've got 47k on my truck and still have 50% left on stock pads. My cummute is 80 miles one way every day. But only maybe 5 of those miles is stop and go. No road course running and not heavy track use.
BD
Old Jun 11, 2003 | 01:33 PM
RipNRun's Avatar
Cali L,
Thx for the reply. I spent most of yesterday washing her down just in case. Squeaking seems to have stopped.
I think I may have had some sand probs. Almost getting stuck on the beach didn't help. Sometimes all that torque can backfire on you, esp if you lose your temper and punch it while deep in the sand
Old Jun 11, 2003 | 04:10 PM
ogieogilthorpe's Avatar
Rob...I just replaced mine at 13k miles. The brake pads had more than half life left and I have a heavy foot. Just upgrade to the napa ceramics and bye bye squeal.
