My first 300 mile tank of gas!
I didn't think it could be done. Doing all the city driving that I do and frequent run-ins with boost, I usually get anywhere from 240-270 miles per tank. Well, before I filled up today, I actually hit 306. I must be doing something wrong...I guess I should floor it more often!
Some of you highway drivers, what is the most miles per tank you've seen out of your L?
I usually don't run mine down that low. Maybe once or twice in 50K. It's not a good idea to run it to the bottom of the tank as 'gunk' may be there, waiting to foul up your pump(s), filter, or injectors.
I just add up the gals. used over several fill-ups and then do the math. Mine is getting 14-15 mpg with about 85% interstate cruising(70-80 mph).
Dan
Dan
The only times I see 300+ miles per tank is when I'm on the highway on a trip and towing at the same time. 2 weeks ago went to Va, made it just past Charlotte from Atl and hit 310 with my trailer and 2 bikes and bed with about 500 lbs of stuff.
In daily driving to work and city can't get past 270
I got exactly 12mpg last time I kept track, and that was a mix of highway and city driving. 300 exactly
I usually get 300 miles out of mine every other fillup. I think the most I saw was 318 miles on a tank. My mpg averages 13.4, with a low of 12.6 and a high of 14.4 (so far!). Lotta highway between work and home.
from full to between quarter and eighth i get 220! WTF. I get like 10 a gallon or 11 if i am lucky. wonder why mine is so low. Ah well life goes on..
I do a lot of around town driving though.
Vinny
I do a lot of around town driving though.Vinny
From my spreadsheet.
2000L
89 Fill-ups
300+mi/tank--45 times
MAX:369.3mi/22.9gal/16mpg--AllHighway trip
Avg miles/tank--297 miles
Avg. fill-up--20 gal
Avg. MPG--15mpg
Total gas--$2846.25
Avg. $/gal--$1.56
2000L
89 Fill-ups
Avg. MPG--15mpg
Total gas--$2846.25
Avg. $/gal--$1.56
I was running on fumes...
But I made 426 miles before a fillup. I was coming back to Alabama from Texas, and pumped up my tires to 35psi all around before I left. I averaged 73.8 mph. Put in 24.2 gal when I filled up, but I filled it to the top of the filler tube.
Worked out to a litle over 18 mpg. That was 95% highway though.
