URGENT Fuel Filter Help!!
Old Jun 4, 2003 | 03:32 PM
VTSVT's Avatar
I'm in the middle of a fuel filter change, and I can't get one of the lines off. I was able to just pull off the line coming from the rear of the truck by hand, but I can't get the line going to the front. I have the metal scissor looking fuel disconnect tool, but how the hell do I use it??
Old Jun 4, 2003 | 03:38 PM
grinomyte's Avatar
Ok you open the tool and clamp it over the little metal thing jutting out of the fuel filter. Then slide it along and make the protrusions go into the line thats attached to your truck. Once you jam it in there good, wiggle the line off the filter. Should be it.
Old Jun 4, 2003 | 03:41 PM
VTSVT's Avatar
Is the tool supposed to clear the ridge on the filter? I've tried to do it like you said but it hits the ridge and won't go over. Is it supposed to?
Old Jun 4, 2003 | 03:50 PM
easterisland's Avatar
Put tool on line.
slide line as close towards filter as possible.
slide tool towards the line.
pull line off of filter.
repeat for other side.
Old Jun 4, 2003 | 03:53 PM
gambinotdx's Avatar
isn't it fun?!?!!?! i've yet to get BOTH sides off on mine. i have that little plastic pac man tool. i got the back end off but couldn't get the front off! i haven't tried that scissor tool yet...that might be next, IF THE DAMN RAIN WOULD STOP ALREADY!!!!!!
Old Jun 4, 2003 | 04:02 PM
VTSVT's Avatar
Finally got it, thanks a lot for your help. Really appreciate it!
Old Jun 4, 2003 | 04:07 PM
VTSVT's Avatar
One last question, should both lines click back into place on the filter, or just the front one??
Old Jun 4, 2003 | 04:13 PM
grinomyte's Avatar
should pretty much click on both, does on mine. just make sure you cant pull it off and theres no leaks, i think youll be fine.
Old Jun 4, 2003 | 04:18 PM
SVT_KY's Avatar
One end of our filter seems to be a bit "over-engineered" ...
I was told that it is really hard to get one of them off
Old Jun 4, 2003 | 05:43 PM
VTSVT's Avatar
Well the back one never did "click" onto the filter. I can see the ridge on the filter right in the opening of the line. I think it was like that before I messed with it though. I was able to take that side off by hand without the tool. Should I worry?
Old Jun 4, 2003 | 05:49 PM
LIGHTNINROD's Avatar
YES! You must get both connectors/collars to 'click' for them to be locked on right. If you turn the key to 'on' so that the pump runs, I'll bet you have fuel spitting out of the rear of the filter without the 'click'.
Dan
Old Jun 4, 2003 | 06:10 PM
Blown93's Avatar
Not much fun changing them.. I know.. For something so simple, its a pain the in the rear... Patients
PEacE.................
(Jim)
Old Jun 4, 2003 | 06:26 PM
Rob_02Lightning's Avatar
I think I may cut those suckers off next time and just use two small clamps.
has anyone done that yet ????
Old Jun 4, 2003 | 06:29 PM
rbraughn's Avatar
I don't know what the big deal is, I got mine off real easy. No problems at all
Old Jun 4, 2003 | 07:21 PM
I always have trouble getting one or the other off too. It seems that the 'collar' unlocks with the tool inserted but there is still alot of friction just wiggling/pulling them off...................
Rob, I wouldn't try clamps as the tube(s) is so small in diameter that I don't think you could get a good seal with clamps. Plus, there is the possibility the clamps would wear thru the hose(s).
Dan
