Cherry Wet questions
Old May 30, 2003 | 04:08 PM
Guapo's Avatar
I've been using Zaino, and I want to try something different, so I think I'm going to go with Cherry Wet. Just a couple questions. Do I have to do anything to strip the Zaino off my truck before using this? Also, can I use the Eagle One, or Meguires quick detailers over the Cherry Wet?
Thanks.
Old May 30, 2003 | 04:25 PM
Dan SS2471's Avatar
As you know, Zaino is very concentrated so you'll have a hard time getting it completely off. Just use Liquid Dawn in a heavy dose. That'll get you close enough to bare clear coat. And rinse WELL!! Otherwise you'll be cursing yourself while trying to remove water spots while you're drying it.
Good luck!!
Dan
Old May 30, 2003 | 04:50 PM
mswaim's Avatar
I've switched from Zaino once before, but I waited until it was in need of a new coat before removing what was left. Heavy dish soap should work. Any of the detailer sprays should work with Cherry, their Miracle Mist is simply awesome, but I've used Eagle One and had no problems. I've had really good luck with all the Coat's products.
Old May 30, 2003 | 05:01 PM
Flying Mofo's Avatar
Banned
Use 100% Isopropyl Alc to remoce zaino complete. Be sure the car is clean before doing so though
