Can i drop the front 1 more inch?
Old May 22, 2003 | 03:36 PM
DaytonaL99's Avatar
I just had the belltech 3/4 drop installed and it looks like the back sits too level with the front; almost looks lower. And yes i did leave the stock shackles on. I like the way the back looks but want more of a rake, so can i get anything to lower the front another inch, like control arms? just an inch not two
thanks in advance
mike
Old May 22, 2003 | 03:52 PM
dirtchicken's Avatar
You could always go with Western Chassis A arms in the front but I think your front end will be too low. My neighbor did the same thing with his and after seeing his stock oil and transmission FULL of nasty dents I decided against this. I already have a deep transmission pan. It does look good though.
Old May 22, 2003 | 06:44 PM
TZRLightning01's Avatar
if you went with 1" less drop Belltech coils (the 2" drop for regular F150 as opposed to the 3" drop #4804 springs you have now), you could run the Western Chassis A-arms and achieve the actual 3" front drop that you are looking for
