Changing the blower belt?
Old May 14, 2003 | 02:50 PM
andrewjhaley's Avatar
Which way does the idler go up or down? I think mine is possibly stuck? I am trying to change the blower belt on a stock 01 L... I can't seem to get it off, and if I did, how would I get it off, do I have to take off the water pump?
Old May 14, 2003 | 02:51 PM
Don's Bolt's Avatar
You take a 1/2 inch breaker bar and push it down and towards the drivers side.
Old May 14, 2003 | 02:53 PM
SpankDog's Avatar
Banned
the worst part is trying to get the belt over the fan, that was a bitch. good excuse to get an E-fan i suppose
Old May 14, 2003 | 03:05 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
just rest the belt over a couple of blades and spin that biatch, or something.
Old May 14, 2003 | 06:57 PM
1/2 inch breaker bar,,, put it where? Do I use any kind of leverage or is it a direct push down
Old May 14, 2003 | 07:22 PM
Crash-n-Burn's Avatar
Put the square drive in the front part of the pulley with the bar pointing upward.Then push hard toward the drivers side and it will rotate downward at the same time.
Old May 14, 2003 | 07:23 PM
Twisted99's Avatar
The pulley has a 1/2" female ..sticlk the male 1/2" braker bar in....push down...towards the ground..while facing the grill..no need to remove the intercooler reservoir...slip the belt off and on behind the pulley...
Old May 14, 2003 | 08:41 PM
redlightspecial's Avatar
I ended up loosening the coolant resevoir and moving it out of the way. In my case, the breaker bar was hitting the resevoir. Maybe it depends on what kind of bar you use.
Old May 14, 2003 | 10:36 PM
SVT_KY's Avatar
Best bet is to use a "Serpentine Belt Removal Tool" ---
Best 68.00 you'll ever spend ... no more cracked knuckles.
Works on MooTangs too ....
Old May 15, 2003 | 01:30 PM
351stang's Avatar
Where do you find a serp belt removal tool? Do the local Autozones carry something like that?
I hate using crowbars on them.
Old May 15, 2003 | 07:53 PM
LIGHTNINROD's Avatar
Sears has them:
http://www.sears.com/sr/mercado/searchall.jsp
But my 1/2" breaker-bar(not a crow-bar) works and that is the way they are designed to be removed.
Dan
Old May 15, 2003 | 10:56 PM
BMWBig6's Avatar
Are you talking about this one?
http://www.sears.com/sr/product/summ...id=00941831000
Or this one? (Not Sears Craftsman)
http://www.sears.com/sr/product/summ...id=00942179000
Old May 16, 2003 | 08:38 AM
Ben: http://www.sears.com/sr/product/summ...n.session.new= Yes. That's the 'common' one that most auto tool stores offer. I've not used either one of them as I said, my 1/2" breaker-bar works just fine.
Dan
Old May 16, 2003 | 03:47 PM
BMWBig6's Avatar
Thanks Dan.
Darn, looks like Craftsman doesn't make a conventional breaker bar.
Old May 18, 2003 | 11:44 AM
SVT_KY's Avatar
Neither of those are the one I was talking about.
Carquest is where I saw mine. A friend has one,
so I haven't had to buy one yet.... <grin> $68
and it does all types with Two extension bars
and 8 different "attachment" methods ...
These are the GATES numbers ...
