Steering and window problem
Old May 14, 2003 | 12:05 AM
Dman25's Avatar
I have a 2000 L, and when i turn the steering wheel all the way to the right i hear a loud popping sound, it doesnt happen all the time, only simetimes. Also when i press the auto window down on the drivers side the window makes a popping sound, it goes pop pop pop, wait like 3 sec then one last pop. Anyone else have these problems. Thanks.
Old May 14, 2003 | 12:09 AM
SpankDog's Avatar
Banned
the first one is "the clunk" the second hummmm
Old May 14, 2003 | 12:11 AM
Dman25's Avatar
Yea, clunk is the perfect word, now what the hell is "the clunk." Should i be concerened and is it harmful or fixable in anyways. thanks.
Old May 14, 2003 | 12:15 AM
Probleminfected's Avatar
where do we get clunk washers now ?
Old May 14, 2003 | 12:20 AM
SpankDog's Avatar
Banned
http://www.johnnylightningperf.com/Links/ClunkFix.asp
Old May 14, 2003 | 12:23 AM
paul12's Avatar
email this guy and buy a set of clunk washers. Then go to this site and check out how to install them.
dplynn@bellsouth.net
https://www.f150online.com/forums/sh...&postid=575595
I will be installing mine tomorrow evening. an alignment will probably be in your future also. you may want to go ahead and get the camber bolt kits from ford. Part number F65Z-3B236-BB. You will need 4 of them. They cost around 10.00 each. It is my understanding that the front end alignment done at the factory is for performance and not for tire wear. The tires will wear on the inside. Once you install these parts you can have an alignment done that will be more friendly to your tires. I have some specs that i pulled from this site if you need them. Good Luck!
Old May 14, 2003 | 12:24 AM
Dman25's Avatar
so is it just annoying or is it something i should be worried about?
Old May 14, 2003 | 12:52 AM
Bryce_Thomason's Avatar
have the same window problem, (99 L with 3500 miles on it) dont know what the problem is but it annoys the crap out of me. thinking about popping the pannel and puttin some grease on the dry parts, i think thats whats causing it.
bryce
