Which Toggle Switch
Old May 13, 2003 | 12:41 AM
My Red-Rocket's Avatar
Question Which Toggle Switch
I bought the flex a lite fan kit and I'm ready to install but I don't know which toggle switch to use as far as power rating goes. I would like to know if I could use a mini 125 volt 10 amp toggle switch. It's on the radioshack web site. I also want to attach a couple of small leds to this switch. What should the ratings on those be. Any help would be greatly appreciated. Thanks!
Kyle
Old May 13, 2003 | 12:46 AM
Sorry forgot to add that the switch is for the manual on feature on the control module.
Old May 13, 2003 | 02:14 AM
Coldie's Avatar
Any
Any switch will do. All your doing is pulling a relay to ground, so virtually no power will flow through the switch. This is very different from how the JDM switch is tpically wired (switching a hot lead instead of a relay).
Coldie
Old May 13, 2003 | 02:24 AM
So to get the LED's to work I would have to run a seperate power wire or tap into one somewhere?
