Plugs
Old May 12, 2003 | 11:54 PM
s.cal L's Avatar
Plugs
Well since I just installed a 2.7 upper to go with the 5# lower, that should be like 8#s over stock, with an agressive racing program, what plugs should I be using? Im currently using TR6s, are those good or to hot? What is recomended? Either NGKs or Densos.
Old May 13, 2003 | 01:43 AM
whtlight01's Avatar
You should be ok running the TR6's But if you feel like tackling a plug swap again I'd go with Denso IT22's maybe even IT24's
Old May 13, 2003 | 08:11 AM
LIGHTNINROD's Avatar
I have a 5 lb lower and run NGK BR7EFs and they have been great. I have a set of Denso IT24s waitin' to go in............
Dan
Old May 13, 2003 | 10:22 AM
easterisland's Avatar
I'm running 20psi + with TR6's for some time now. Contact the guy who does your chip and ask him what you should use.
