Lightning transmission fluid+FTVB
Old May 11, 2003 | 09:01 PM
Blwnsvt01's Avatar
I am getting ready to install a FTVB and 4X4 pan, i have a case of transmission fluid i have had for a couple of yrs its Motorcraft MERCON and then it has also meets DEXRON-III i was thinking can this be used in the 01 lightning transmission. I do not want to HURT anything? ANY HELP WITH THIS WILL BE helpfull
Thanks in advance.
Old May 11, 2003 | 09:09 PM
conleymotorspts's Avatar
I just did that mod right before the nmra event in columbus after the install it took aprox. 8qts of mercron fluid great mod everyone on the board will agree.
Old May 11, 2003 | 09:13 PM
Probleminfected's Avatar
i'm wondering if that b&m trick shift will work good in the 4r100?
Old May 11, 2003 | 09:17 PM
you would be waisting your money just get a good brand fluid from auto zone or wallyworld or wearever you shop. that's all that the b&m stuff is they just repackage it.
Old May 11, 2003 | 09:19 PM
thanks for the info
Old May 11, 2003 | 09:26 PM
Blwnsvt01's Avatar
Fluid - is this one OK
I am trying to find out if this fluid is ok to use to refill the trans. Thanks for your help.
Old May 11, 2003 | 09:56 PM
69stangscj's Avatar
Registered User
Re: Fluid - is this one OK
Is this the stuff you have? It's recomended by FT. along with Mobil One.
Old May 11, 2003 | 10:23 PM
Blwnsvt01's Avatar
ONLY IN A BLACK BOTTLE
yes only in a black container is there a difference between the red bottle and the black????????
Old May 11, 2003 | 10:41 PM
booger's Avatar
if b@m is the same why is it blue?
Old May 11, 2003 | 11:00 PM
Factory_Tech's Avatar
Different color dye. Tranny fluid is naturally clear/amber, they dye it.
The red bottle is fine, so is the black, they just changed the bottle.
G
Old May 11, 2003 | 11:10 PM
booger's Avatar
So I guess valvoline, penzoil,quakerstate,castrol gtx are the same but their in a differant bottle.I thought b@m was based more toward type F for firmer shifts.
Old May 13, 2003 | 04:44 AM
Ther are slight differences, but essentially they're not too different. The different types are diferent chemical bases, made to be compaitble with the friction plates and seals in the box. Use the wrong kind and you can disolve the selas or the friction material. I did have a quart of one of those fancly fluids analyzed once, teh guy in the lab told me it was about the same as WalMart brand in an expensive bottle.
Motorcraft is Fine, Mobil 1 synth is better in hot climates, and that's about the gist of it. I swear I'm gonna start selling fluid, there is one additive that makes a diffenrce in clutch wear (it's really good) and other than that I don't see much difference in any name brand, certainly anyone who tells you they can tell the difference from driving it either has the wrong fluid or is fooling themself.
G
Old May 13, 2003 | 05:40 AM
Flying Mofo's Avatar
Banned
G
So whats the additive?
Old May 14, 2003 | 03:59 AM
I'm not telling.... at least not right away. After I wrote it I got to thinking, and I just may start selling it. I could sell 5 gallon buckets of fluid with it allready in it, cheaper than Mobil 1 but a little more than Motorcraft...hmm,, I just may do that.
It's not generally availible, the company that makes it hasn't even considered it for use in transmissions, it's just something that is good for the plates, i heard about it from a Raybestos rep a long time ago and I've used it since. The make it for some kind of aviation power couplings that Raybestos makes the friction parts for. You can't tell any difference in driving it, but you can see the difference when you tear down the box. I put it in every Monster Box already, it only takes 12 oz for the fill. It's a synthetic ester, before I actually sold it I'd have to get more detailed info on it, but it's pretty neat stuff.
G
Old May 14, 2003 | 04:57 AM
Banned
Lemme buy some off of you. Its going to start getting hot out here next month
