Will a bad TPS cause shifting problems?
Old May 9, 2003 | 02:07 AM
Skank Dog's Avatar
Just trying to figure out why my tranny went from short,firm shifts to early sloppy shifts after installing ported heads and a Billetflow T/B that came with a new TPS. Does a TPS have anything to do with the way these transmissions shift?
Old May 9, 2003 | 02:11 AM
cpeapea's Avatar
i believe in a way, but not sure with what you describe. is it adjusted right? what does the voltage read?
Old May 9, 2003 | 02:30 AM
Calightnin's Avatar
Yes it will.
Old May 9, 2003 | 08:20 AM
LIGHTNINROD's Avatar
Oh ye of little faith............
Dan
Old May 9, 2003 | 02:00 PM
Skank Dog's Avatar
Well, problem is solved! I pulled the new Blilletflow off and installed the old T/B and things are back to normal. WTF? So Im thinking its the TPS, So I reinstalled the Billetflow with my old TPS and it still shifted like a dog.
So, guess the new T/B will be going back for a refund. Ive never heard of anyone having a s/b t/b giving them tranny troubles, oh well, thats my luck. Anyone know why the Billetflow made the tranny shift so soon and sluggish?
I miss the hissing noise already and the throttle response isnt as crisp, but oh well............
Old May 9, 2003 | 02:22 PM
Calightnin's Avatar
Did you adjust the TPS properly?
Old May 9, 2003 | 02:31 PM
Skank Dog's Avatar
Calightnin- TPS on the new Billetflow was set at the factory and I adjusted it every which way with no success. I cant figure this one out at all! Weird. It doesnt matter on the stock T/B were its set, the tranny shifts fine either way.
Old May 10, 2003 | 08:29 AM
dougwg's Avatar
I'm sorry but BilletFlow does NOT "factory install" TPS'
You Must set the TPS voltage.
After you set the TPS you Must reset your computer.
Maybe you should call the "factory" and see if they can help.
Hope this helps
Doug
Old May 10, 2003 | 08:57 AM
Rob_02Lightning's Avatar
Shank,
I couldn't get the proper adjustment on mine either.
I had to drill the TPS to get the right reading.
I couldn't adjust mine either, so I took the TPS off.
I drilled the holes out to give me more adjustment, it's only plastic that was a piece of cake.
Picture explains it all. "NOW IT'S CORRECT" .980
Old May 10, 2003 | 09:50 AM
Crash-n-Burn's Avatar
Rob and Tim Skelton should team up on one site for info and how-to's.Ford would probably send the link to their dealers service departments.
Old May 10, 2003 | 10:05 AM
Fast Gator's Avatar
LOL, yeah ain't that the truth
But I think, Ford would get pissed with Rob yelling.........Give Me Head w/Thread
BTW....my TPS needed to be "drilled" to set the voltage properly
Old May 10, 2003 | 10:57 AM
Skank Dog's Avatar
Ahhh, Rob you da man!! Thanks for the info. Ill try that because this TPS has nearly zero movement!!
dougwg- The "factory" I was referring to was LFP where I bought it, he sets the TPS for you, guess I should have made myself a little more clear. They dont come with a TPS from the manufactuer.
Old May 10, 2003 | 11:13 AM
No Prob Shank,
Anything to help a Brother out.
I bought mine from Mark Too, (great price)
Your right he also told me the TPS was installed "and adjusted"
To tell you the truth I ran mine for quite some time before adjusting it, and it ran perfect.
I really didn't feel a difference after I adjusted it either.
Mine was @ .50 before I adjusted it. But since it's an electronic ran switch, that plugs into YOUR LIGHTNING, I guess you got to expect it to need adjustment anyway, MINE DID.
Now if I can only get rid of the ****ing annoying
whistling sound
Old May 10, 2003 | 11:19 AM
MISTERgadget's Avatar
Rob,
Yo can get rid o the annoying whistle if you line up the throttle body with the upper plenum. If the TB's opening is still too big, you can pull off the plenum and match it's opening to the TB's, then no more whistle.
Old May 10, 2003 | 12:05 PM
Skank Dog's Avatar
Rob- I dunno man, I kinda like that whistle! I think it sounds bad a$$, kinda like a pop off valve on a turbo or something. It sure turns people's heads when leaving a redlight.
