How 2 install my LINE VALVE and 4x4 PAN?
Looking to install my JDM valve and 4x4 pan this weekend on the Harley.
Is there a DIY to follow, or should i just pay to have it installed?
thanks
thanks
i use to live in Edison, off of Main Street
i always use to see a White Lightning parked over by the PSE&G power lines, right off of Rt1.. the big field.. would that happen to be you?
email me if you think ya have time this weekend, ill bring the
chris03hd@comcast.net
MAke sure you have an Inch pound torque wrench
Dont pay anyone to install it .Easiest way is to drill a hole in your stock pan carefully and let it drain .Unbolt your pan and when you pull the filter out open your mouth wide and close your eyes
then remove the VB and you replace the 1 valve . WHen you replace the VB is when you need the Inch # torque wrench . I went and bought a cheap one from home depot for like 35 buck because i figured id only use it once or twice.. Its all really easy just take your time and drink lots of beer .Besides it feels better when you do shiat yourself ..
