Who is making the most power on a stock block/bottom end?
Old May 8, 2003 | 06:35 AM
loosebolt's Avatar
I have just finished doing a little work and was wondering how much power the stock block, especially rods, can handle
Also, let's say I was making 450hp with a 4#, vs 450hp with a 6#, would that make a difference or is it all about the hp?
Old May 8, 2003 | 08:16 AM
soap's Avatar
It's all about the hp.........doesn't matter if you make it using a 2# or an 18# pulley.
--Joe
Old May 8, 2003 | 09:35 AM
blown318's Avatar
I am making 10000 horsepower at the wheels!!! LMAO!!!!!
Old May 8, 2003 | 11:32 AM
99svtlightning's Avatar
JJ and JLP are throwing out some fast ET's with the stock block. JJ is his Lightning and JLP in their Harley truck.
Old May 8, 2003 | 12:24 PM
Dale-01L's Avatar
Im sure Im not making the most (In fact I know Im not)
But I made 466/605 SAE last time on a dynojet
No problems with rod-escapee's
-Dale
Old May 8, 2003 | 12:25 PM
svt360's Avatar
im read that 500HP is the cutoff for stock bottom end
Old May 8, 2003 | 12:32 PM
loosebolt's Avatar
-Dale
Cool!
How hard do you drive your truck and do you put a lot of miles on it?
svt360, I heard about 500-525 also. So, at the rear wheels, assuming 12% loss, that would be about 450...which means the limits are being tested.
Old May 8, 2003 | 12:35 PM
loosebolt's Avatar
Chris, those numbers must be with all that NNNNAAWWWZZZZ!
Old May 8, 2003 | 02:33 PM
Dale-01L's Avatar
Ive got about 10,000 miles on it at that power level. I drive the truck everyday, and Im not easy on it by any means, but I also dont WOT it constantly...
-Dale
Old May 8, 2003 | 03:16 PM
lurker's Avatar
-Dale
466/605 on California gas? That's impressive.
Old May 8, 2003 | 09:32 PM
blown318's Avatar
Old May 8, 2003 | 10:38 PM
smknjoe's Avatar
RedBolt99
I believe that is his name on this board, is making 495 SAE RWHP on on Danny Swansons dynojet. I dont remember the torque. He has made several passes with that setup. I believe that this might be the most with a stock bottem end.
Old May 8, 2003 | 10:59 PM
RTKILLA's Avatar
Cool!
500 to 525 is at the rear wheels brother, depends though. the 99 and 00 motors seem to have better rods that will handle the 500 rear HP, but the 01+ motors have different rods and they seem to bust allot more with allot less power in cases.
Old May 9, 2003 | 12:44 AM
frank2's Avatar
420 rwhp
513 torque
not track tested yet
Old May 9, 2003 | 02:18 AM
cyntaxx's Avatar
I know of a guy with a 99 that did an 8# and sprayed a 150 shot on his stock block. Ran solid 11s. Now going with a built motor but when he did a leak cheak on his stock one, he found nothing wrong....
