help
Old May 7, 2003 | 07:17 PM
WhtSvt's Avatar
Question help
my steering wheel shakes for some reason i just got new nittos put on and check the alignment.what else could it be. could it have something to do with the brakes? thanks
Old May 7, 2003 | 07:20 PM
cyntaxx's Avatar
Could be a warped rotor if you're experiencing this only when braking from certain speeds, etc.....
Old May 7, 2003 | 07:27 PM
SpankDog's Avatar
Banned
tires are outta balance......
Old May 7, 2003 | 07:30 PM
LIGHTNINROD's Avatar
What Spank said...............
Dan
Old May 7, 2003 | 08:27 PM
SVT_KY's Avatar
What Dan said ...
Old May 7, 2003 | 08:29 PM
blowntruck's Avatar
What they said.
Old May 7, 2003 | 09:06 PM
Thor01's Avatar
I just had a set of nittos put on. The guy had them filled up to 39PSI. Only torqed the lugs to 90lbs-ft. Again not right.
1.) Check and make sure all the lugs are torqed. If they
just used an impact, not good enough.
2.) Check tire PSI.
3.) Still does it after checking 1 & 2. Go back and have the tires re- balanced.
